1989 Buick Riviera Stalls on Decel
GWOEHREL
I have a 1989 Riviera, 3.8, 35,000 miles. Yes 35,000. When I slow down to turn or stop it stalls.It does not sputter, it cuts off quick. Starts right back up.This would happen very seldom. Now it happens constantly. The error codes were 41 and 42. I replaced the Camshaft position sensor and I no longer get error 42. But It still stalls. Then I replaced the ignition model and the coil pack, but it still stalls and I still get error 41. I read through most of your forum but I did not see anything simular. I would appreciate any suggestions. The books I have list alot of possibilities for code 41.
May 7, 2007 at 2:54 PM
2CARPRO JACK
  • 11,533 POSTS
3.8's had problems with the crank angle sensor as well, try that first.
May 8, 2007 at 1:13 AM
GWOEHREL
Thanks Jack, I don't want to assume anything, so is the crank angle sensor the same as the crankshaft position sensor that is mentioned in my repair manual?
May 8, 2007 at 10:51 AM
GWOEHREL
Does anyone know where I can find a crankshaft postion sensor alignment tool for 1989 buick 3.8? It does not seem easy to find even on the web.
May 8, 2007 at 1:31 PM
Suggested Repair
Check the crank angle sensor first. On these 3.8 engines it is a common cause of stalling and code 41, and it should be inspected or replaced before further parts are swapped.
Conversation Summary
A 1989 Buick Riviera with the 3.8 engine stalls abruptly when slowing to turn or stop, then restarts immediately. Codes 41 and 42 were present. Replacing the camshaft position sensor cleared code 42, and replacing the ignition module and coil pack did not stop the stalling or clear code 41. The expert advised trying the crank angle sensor first because 3.8 engines commonly had problems with it. The owner then asked whether that is the same as the crankshaft position sensor and where to find an alignment tool, but no further reply was given.
