86 buick regal wont start
LUCKY820
I have replaced the timing chain, cap, rotor,wires plugs, coil and I am not getting any spark still what could the problem be Please help....Paul
Oct 20, 2007 at 6:00 PM
CLY
  • 308 POSTS
If you have power everywhere then I would probably suspect that the ignition module is faulty. did the car run before you did the timing chain?
Cly
Oct 21, 2007 at 12:38 AM
CLY
  • 308 POSTS
Inbox :: Message
To: Cly
Posted: Sun Oct 21, 2007 11:49 am
Subject: 86 buick regal
the car stop running while driving it then when I took everything apart the time chain sproket was worn down to nothing so I replaced that to start with then everything else.
I would deffently lean tawords that ignition module then...You may want to call some auto parts stores. I know that some of them have a tester that they can put it on and check it out for ya....
Cly
Oct 21, 2007 at 3:57 AM
