2002 Buick Regal Key Stuck in Ignition
JDSPINNER
I have a 2002 Buick Regal with 93000 miles. It has a V6 engine. The problem I am having is that when I turn the car off I cannot remove the key. I am unable to turn the ignition switch far enough to remove the key. This does not happen every time but frequently. If I start the engine then shut it off several times, I will be able to remove the key. Sometime it will take up to 10 minutes before I am able to remove the key. Any ideas?? :D
Jul 30, 2007 at 4:21 PM
CLY
  • 308 POSTS
I would take a look at the solenoid on the side of the floor shifter. It gets stuff spilled on it and then starts sticking. It will look like a white plunger. If you move that the key will come out. The only way to repair it is to replace the shifter assemmbly...
Cly
Jul 30, 2007 at 9:44 PM
Suggested Repair
Inspect the shift-interlock solenoid on the side of the floor shifter. A sticking white plunger, often from spilled liquid, can prevent key release; moving it may free the key. The repair is to replace the shifter assembly.
Conversation Summary
The owner of a 2002 Buick Regal with a V6 and about 93,000 miles often cannot turn the ignition far enough to remove the key after shutdown. Restarting and shutting off the engine several times sometimes frees it, and the delay can last up to 10 minutes. The expert advises checking the floor-shifter solenoid and its white plunger for sticking, and replacing the shifter assembly if needed.
