My '98 Buick Regal 3.8 Supercharged is leaking oil from the oil pan. I had a mechanic check it out and that is what he found. I want to replace the gasket but it looks like I have to remove an engine mount to get the pan off. Will I need to lift the engine with a hoist or can I support the engine from below? Also can the gasket be cleaned and re-used with some RTV? It costs about $100 to replace the gasket which is rather steep for a gasket.
Mar 1, 2006 at 9:19 PM
