Engine Mechanical problem
1998 Buick Regal 6 cyl Front Wheel Drive Automatic 115k miles
My car will not start, and I know its not the battery because I check it? Any ideas
Monday, October 12th, 2009 AT 1:22 PM
BIG_JAY
MECHANIC
Can u please b a little more specific. Does it crank over and not fire up or does it not crank over at all?
SPONSORED LINKS
Monday, October 12th, 2009 AT 1:37 PM
SALICKRAM01
MEMBER
It does not crank at all. When I turn it on the light comes on tho! So I don't know the problem.
Monday, October 12th, 2009 AT 4:19 PM
BIG_JAY
MECHANIC
Check all of your fueses. If they are good u need to hook up a test light to the ground side of your battery and probe the small wire on the starter. If the light lights up u know u have a bad starter. Also just make sure the big wire on the starter has power at all times.
