My Car will not start
111,000 MILES • 3.8L • 6 CYL • FWD • AUTOMATIC
MARY DIAL
I have a new battery, good starter, but It will not start, I can hear a clicking sound under the dash, all of the lights in the dash come on. I don't hear the fuel pump come on like it isn't getting power to the starter or fuel pump.
Mar 15, 2016 at 12:45 AM
HMAC300
  • 48,601 POSTS
I suggest trying a different key if you have one. If that doesn't fix the problem it could be the security system.
Mar 15, 2016 at 1:12 AM
MARY DIAL
I tried my other key still would not start. I had it installed when I had a radio put in..
Mar 15, 2016 at 3:01 AM
HMAC300
  • 48,601 POSTS
What did you have installed? if this problem has cropped up since the radio was installed. There is a chance it was hooked it up incorrectly. I would suggest having the radio installer take a look at the problem.
Mar 15, 2016 at 5:02 AM
MARY DIAL
Sorry, I meant that I had a security system installed. I couldn't use the key pad to lock doors, when my radio was installed they fixed the key pad so I could use it to lock my doors and that was two years ago. I haven't had a problem with it until now.
Mar 15, 2016 at 8:01 AM
HMAC300
  • 48,601 POSTS
I suggest having the person that installed the security system and fixed the key pad to take a look at the car.
Mar 15, 2016 at 9:18 AM
MARY DIAL
Ok thanks for your help HMAC 300....
Mar 15, 2016 at 9:46 AM
