1997 Buick Regal shut down
NATALEE1369
  • 1997 BUICK REGAL
Electrical problem
1997 Buick Regal 6 cyl Automatic
Sometimes the car won't start. The engine won't even turn over. While driving, if I use a blinker, the car will completely shut off. Then it takes a while of toggling with the gear shifter from back to forth, and the car will start while in neutral only. I figure it is electrical since it shut's down when using the blinkers, but I don't know.
HELP!
Monday, April 6th, 2009 AT 3:39 PM
  • 109,885 POSTS
Hi:
First, if the engine only starts in neutral, chances are the neutral safety switch is bad. As far as the blinkers, check for ground problems. If none are found, have the body control module (BCM) tested.
Let me know what you find.
Sunday, May 3rd, 2009 AT 4:52 PM
