1995 Buick Regal
PHYFIER
  • 1995 BUICK REGAL
1995 Buick Regal 6 cyl 90000 miles
1995 Buick regal custom 3.8 engine. My car sometimes stops during driving or won't start after I get somewhere. Every time I get it looked at it runs fine. Lately it stops more often. Any idea. Wat The problem is
Tuesday, April 13th, 2010 AT 12:29 AM
Next time it won't start do below to determine what's causing it, if its fuel or spark problem
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Tuesday, April 13th, 2010 AT 6:51 AM
