Computer, sensor at cam shaft, sensor at distributor
all been replaced. No codes showing. Intermittent problem. Car starts fine, then won't start. Not a fuel problem. All obvious problems eliminated. Any ideas?
Friday, October 2nd, 2009 AT 9:48 AM
MATHIASO
MECHANIC
Starter on his way out can cause that problem.
SPONSORED LINKS
Friday, October 2nd, 2009 AT 5:03 PM
JERRYGOODWRENCH
MECHANIC
Try checking the fuel injector pulse. One faulty injector winding will cause this problem. Even if you have fuel to the injector it may not have injector pulse. Disconnect ea injector plug and use a good ohm meter and measure resistance should be around 11 ohms or so on ea one. One or two way out of range will shut down computer. Try that and let me know.
