Do you think the security system might be causing an issue? Your saying the starter won't crank? You need to be sure the battery has a full charge. Use a digital multimeter, everything turned off, the generic spec for a full charged battery is 12.6 volts. Make sure the battery connections are all clean and tight. The purple wire at the starter solenoid, is it hot with the key in the crank position? Any testing, make sure the tranny is in park or neutral and the e-brake is set.
SPONSORED LINKS
Thursday, May 13th, 2010 AT 4:22 PM
