1993 Buick Park Avenue No Start
DAVID MARLOW
109,000 miles 3800 engine
While driving the car, it just died. Started back and drove home with much difficulty(kept dying) Got home and noticed when I turned the switch to the on position that the fuel pump was not making a noise. I put in a new fuel pump and it is now buzzing when you go to the on position. The car still sputters and spits, but will not start. What else should I do? Bleed the fuel line, etc.
Thanks very much
Oct 8, 2007 at 5:50 AM
MERLIN2021
  • 17,250 POSTS
Check your coil pack, pull the wires out 1 by 1 and check for rust, if all are good then check for spark at each wire, Pull the fuse for your fuel pump first! If spark is ok at all wires, check fuel pressure with a gauge!, last check engine compression, you may have jumped a tooth on the timing chain.
Oct 8, 2007 at 6:04 AM
Suggested Repair
Check the coil pack and plug wires for rust and spark at each wire, with the fuel pump fuse pulled first. If spark is good, measure fuel pressure with a gauge, then check compression in case the timing chain jumped a tooth.
Conversation Summary
A 1993 Buick Park Avenue with a 3800 engine died while driving and kept stalling. The fuel pump was silent with the key on, so it was replaced and now primes, but the engine still sputters and will not start. The expert advises checking the coil pack and wires for rust and spark, then fuel pressure, then compression for a possible jumped timing chain.
