2000 Buick Park Avenue Car doesn't start or stalls after st
CYNTHIA FINKE
  • 2000 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 86,500 MILES
Do not know if we have a ECM problem - Fuel sensor- or something else. We have replaced the Fuel pump.
Wednesday, May 20th, 2009 AT 4:55 PM
You need to determine if its fuel or spark problem-Do below and comeback with some results
Get a starting fluid/ether/better off gas in a spray bottle and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, May 20th, 2009 AT 5:28 PM
