Are you saying it cranks good, but won't start, or it won't even crank? Do you think your security system might be causing an issue? The purple wire at the starter solenoid should be hot with the key in the crank position, is it? When fooling around with starter, make sure the tranny is in park or neutral, e-brake is set. Some of the national brand autostores will test the starter for you, if you take it to them.
SPONSORED LINKS
Thursday, July 1st, 2010 AT 1:03 PM
