1997 Buick Park Avenue DOOR LOCKS & ALARM
1997 BUICK PARK AVENUE
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOOKLOVER5050
WHY IS MY AUTOMATIC DOOR LOCKS & ALARM SUDDENLY GOING OFF (DOOR LOCKS RANDOMLY LOCK OVER & OVER ( ALARM KEEPS GOING OFF AT RANDOM WHEN i AM GETTING IN & OUT OF THE VEH
Dec 23, 2009 at 2:38 AM
MERLIN2021
  • 17,250 POSTS
So the alarm sounds and dorr locks keep locking, this only happens if the drivers door is opened? any door is opened? Car starts OK? This happens even with the key in the ignition?
Dec 28, 2009 at 7:58 AM
BOOKLOVER5050
it happens when any door is opened, at random....not EVERY time, but YES if the key is in the ignition also...nothing seems to prevent it...the locks are random as well...I'll be going down the road & the locks are constantly locking over & over...the alarm only going off as I am exiting or entering the vehicle
Dec 28, 2009 at 8:02 AM
BOOKLOVER5050
I still have not received any possible repair suggestions, just questions...can someone help me with this??
Dec 29, 2009 at 6:46 AM
MERLIN2021
  • 17,250 POSTS
There are many possiblities, and a scan with a GM Tech II scan tool would be the easiest way to find the bad part, other than that REQUIRED starting point, you will spend many hours, and mabe a few unneeded parts will be replaced along the way without the scan. I can send some reading about it so you can see that even with a scantool, there are many tests to perform, in your case I will say it sounds like an intermittent problem and could be a ground wire problem. There are sensors in each door lock, and the trunk lid, any of those could also cause this. What does the security light on your dash do when you enter the car? insert key and turn it to on? start car? Does the light EVER come on with the car running?
Dec 29, 2009 at 7:51 AM
BOOKLOVER5050
the service engine light has been on since I bought the car from my dad 3 years ago. I don't know what the security light shows. thanks for your suggestions, I will just have to take to a shop
Dec 29, 2009 at 8:10 AM
MERLIN2021
  • 17,250 POSTS
The service engine light means the PCM(computer) has detected a problem and has stored a code for it. scan please!
Dec 29, 2009 at 8:16 AM
DON IRWIN
I had basically the same problem, my door locks kept cliking and locking but I had turned off the alarm using the DIC controll, as for the locks by chance I changed the master controll on the drivers door and this stopped the locks from clicking and never had the problem since, maybe I lucked out but it's worth a try, cost me $10.00 at the wreckers
Mar 19, 2010 at 10:33 AM
MERLIN2021
  • 17,250 POSTS
Thanks Don, you did luck out! $10.00? a bargain!
Mar 21, 2010 at 2:59 AM
