1994 Buick Park Avenue water pump and moter mount
TRILLSMOKER
  • 1994 BUICK PARK AVENUE
  • 6 CYL
  • FWD
  • 220,233 MILES
I'm trying to get the water pump off but the motor mount is in the way. I try to take the motor mount off but the screws on the fram of the car are to tight and I can't get it off so i'm stuck please help
Tuesday, December 2nd, 2008 AT 8:02 PM
DOCFIXIT
  • 18,828 POSTS
Rent electric impact wrench or breaker bar with cheater pipe ie. Georiga Impact. Be sure to support engine floor jack a block wood on oil pan
Wednesday, December 3rd, 2008 AT 8:54 AM
JTMONEY11086
  • 17 POSTS
Yes the motor mount is a bit frustrating, unbolt the motor mount from the motor and jack your motor up a bit see if u cant squeeze it out. Note there are 2 10mm bolts they are hard to get to u do not need to take them out to get the mount off. The reason they are hard to get to is because they are the water pump bolts and 2 holes were factory drilled for the heads of the bolts to just sit in there. Goodluck I did it it wasnt fun:)
Tuesday, June 16th, 2009 AT 8:05 PM
