1998 Buick Park Avenue Coolant Leak
1998 BUICK PARK AVENUE
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
IBEALION
  • 8 POSTS
I was told by my mechanic that I have a coolant leak and that a belt needs to be replaced because the coolant is leaking on the belt. Is it reasonable that the belt should need to be replaced?
Mar 9, 2010 at 7:04 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
If the coolant has been leaking on the belt for a while, it may affect the rubber and cause a squeal, if the leak has only been short term and minor, don't worry just now, you should not have a need to be replacing the belt just yet.
mark (mhpautos)
Mar 9, 2010 at 8:35 AM
