When starting the car the hose from the thermostat is very soft and nothing coming from it as well. Is this normal? If not, what could be wrong?
Jan 4, 2007 at 11:50 AM
A soft thermostat hose after the cooling system cools is normal because system pressure drops. Confirm coolant is still present, keep the radiator and overflow full, and never open the radiator cap while the hoses are hot.
The owner reported that the hose from the thermostat was very soft and had nothing coming from it when starting the car. The expert explained that a cooled cooling system releases pressure, so a soft hose can be normal, but coolant should still be present. They advised keeping the radiator and overflow full and never opening a hot radiator cap.
