1996 Saturn SL1 Oil in Coolant
You can and should flush the cooling system. I start by draining the system cold. :!: Use caution as antifreeze is poisonous. :!: If you spill be sure to clean up any puddles.
Next remove the thermostat and reinstall the housing. Be sure to use a suitable tool (will be supplied with new thermostat).
Mix 2 ounces of automatic dishwashing detergent (any low sudsing detergent will work) per gallon of water.
Fill the cooling system and run it for 5 minutes. Drain it out afterwards. :!: Caution don't open hot! :!:
If the coolant was real dirty repeat the last 2 steps.
Next fill with clean water, run for 5 minutes, and then drain.
Next replace the thermostat with the new one.
Lastly add a 50/50 mixture of the correct antifreeze (check owners manual) and distilled water.
You might consider removing the coolant tank and cleaning it in the sink. It does not get the circulation of the rest of the system. This will keep the dreaded low coolant light from flashing at you needlessly. Couple of mounting bolts, hoses, and one electrical connection is all it takes. I do this as a last step of a flush before filling with new antifreeze mixture.
Good lluck and let us know. :)
So, off to the dealership I go. :( Hoping it will be less than $1000, but not holding my breath.
Good luck and let us know. :)
Also a used engine is an option. $500. or less and about $500.00 for installation could be an option.
See this link for finding a quality garage.
https://www.2carpros.com/kpages/avoid_car_repair.htm
I was able to buy a 2005 Ford Focus with 9000 miles. So now I'm selling the Saturn to someone who has the knowledge and desire to fix it.
Thank you again for your help :)
Suggested Repair
The thick dark fluid was oil, not degraded coolant, from a failed head gasket and a cracked cylinder on the SOHC engine. A cooling-system flush will not fix that. Compare a dealer repair with an independent Saturn-knowledgeable shop, a used or rebuilt cylinder head, or a used engine with installation.
Conversation Summary
The owner of a 1996 Saturn SL1 reported thick, dark coolant and asked how to tell it from oil and whether a flush or a new radiator was needed. The expert advised checking the oil filler cap and dipstick for a milkshake appearance, then outlined a careful cooling-system flush if the coolant was only old and dirty. A mechanic later found no coolant left and oil throughout the system, with damage between cylinders 2 and 3. The dealer confirmed a cracked cylinder and quoted about $2500. The expert noted known SOHC head-cracking issues and suggested a knowledgeable independent shop, a used cylinder head, or a used engine as lower-cost options. The owner instead bought another car and planned to sell the Saturn to someone willing to repair it.
