1999 Toyota Corolla Inlet Heater Hose
TIM_1979
I am trying to flush the radiator of my 1999 Toyota Corolla. It has approx. 121,000 miles. I have a Prestone Flush-n-Fill Kit, but I cannot identify the inlet heater hose. How can I tell which is the proper hose to cut into? Any help will be appreciated. Thanks
Oct 15, 2006 at 6:00 AM
FRANCIS 180
  • 18 POSTS
g'day tim the inlet hose is the one with a valve on it and a wire attatched. probably right hand side looking from the front. good luck with it :D
Oct 15, 2006 at 10:09 AM
  • 75,988 POSTS
[quote:5d2dfb3869="tim_1979"]I am trying to flush the radiator of my 1999 Toyota Corolla. It has approx. 121,000 miles. I have a Prestone Flush-n-Fill Kit, but I cannot identify the inlet heater hose. How can I tell which is the proper hose to cut into? Any help will be appreciated. Thanks[/quote:5d2dfb3869]
Disconnect the both heater hose,start the car the one that push coolant is what you're looking for.do it real quick.
Oct 15, 2006 at 6:30 PM
Suggested Repair
Disconnect both heater hoses and briefly start the engine. The hose that pushes coolant out is the inlet heater hose for the flush kit. Do this quickly, then shut the engine off.
Conversation Summary
The owner of a 1999 Toyota Corolla with about 121,000 miles could not identify the inlet heater hose for a Prestone Flush-n-Fill kit. One reply suggested the hose with a valve and attached wire, likely on the right when viewed from the front. The expert advised disconnecting both heater hoses, starting the engine briefly, and using the hose that pushes coolant as the inlet.
