Buick Blower Motor Test
BUICK
THEMARCIAN
  • 29 POSTS
how do you test the blower motor using a battery a nd wire?
Nov 17, 2006 at 7:25 AM
LOSONE
  • 1,616 POSTS
Unplug the blower motor connection and apply 12 volts across the two terminals on the blower motor.
The most common failure in a Buick is the controller or the resistor not the blower motor. Good luck
Nov 17, 2006 at 7:32 AM
Suggested Repair
Unplug the blower motor connector and apply 12 volts across the two motor terminals. If the motor does not run, it may be faulty, but the controller or resistor is a more common failure on a Buick.
Conversation Summary
The owner asked how to test a Buick blower motor with a battery and wire. The expert advised unplugging the motor and applying 12 volts across its two terminals, and noted that the controller or resistor fails more often than the blower motor.
