Can you tell me how to access the blower motor on a 1995 Buick Regal? 3.1 liter motor, 100,000 miles.
Wednesday, February 21st, 2007 AT 8:27 PM
CHEVY22
MECHANIC
Its located under the right side of the dash, remove the lower panels below the glove box and you should see it, dont break the blower motor resistor,
good luck
SPONSORED LINKS
Wednesday, February 21st, 2007 AT 9:04 PM
BHUGG
MECHANIC
Before you remove the blower motor, make sure that the motor is the problem.
There is often another fuse and relay for the blower motor.
Does the motor work at all?
What are the symptoms that made you want to replace the motor?
Thursday, February 22nd, 2007 AT 11:06 PM
DGRAY65
MEMBER
Yes the motor does work. The problem is a whining noise that comes from it when the a/c, defroster, heater or vent is turned on. Not sure if there is a bearing going bad or if something has fallen in behind the dash and is touching the blades. The faster the blades turn the louder the noise is.
Saturday, February 24th, 2007 AT 9:47 AM
BHUGG
MECHANIC
Then it sounds like you are looking up the right tree.
Good luck.
Saturday, February 24th, 2007 AT 12:38 PM
CHEVY22
MECHANIC
Well its one of the two, sometimes thing do fall in the housing, I would reccomend pulling it and checking, this way you will find whats wrong
thanks
jim
SPONSORED LINKS
Saturday, February 24th, 2007 AT 12:39 PM
DGRAY65
MEMBER
I can't really see any panels behind the glove box. Does the glove box need to be removed and if so what's the best way to remove the glove box? Thanks.
Tuesday, February 27th, 2007 AT 3:43 PM
DRAGONRIDER99
MEMBER
I had the same problem with my 1996 Regal. I simply took out my glove box. Just remove the metric screws mounting it. There are 2-3 below it and a couple inside. Remove the bulb inside first. In my case, some paper had fallen out of the glove box into the blower housing. Drove me crazy for 3 weeks. Took all of 10 minutes to pull the box, pull out the paper and fix it.
