A/C blows one side cool, other side not cool. (Not cool)
METATLVI
  • BUICK PARK AVENUE
Buick park avenue 1998 3.8 L auto-trans front wheel drive mileage 120k-
- with A/C on, even on recirculate & vent off, left side blows cool like normal, but right side blows air-temp air (not hot or cold). Elec system seems ok; (no vacuum lines on back of A/C control unit in dash); not sure if the 98 year has vacuum lines. Is the problem in vacuum lines or other? Thanks.
Saturday, July 7th, 2007 AT 3:05 PM
2CARPRO JACK
  • 11,533 POSTS
I take it this car has dual climate control? Could be an control actuator problem if it has dual.
Sunday, July 8th, 2007 AT 8:11 AM
METATLVI
The closest to 'dual climate' is at the vents on each side where theres an elec slide control labled 'cooler--warmer'; both are set to 'full cool'. No such dual control on mail control panel. Is it worth 75.00 to swap out the main control panel with a used one? (I dont see any loose wires). Thanks
Sunday, July 8th, 2007 AT 1:03 PM
2CARPRO JACK
  • 11,533 POSTS
I would start by checking that those controls are working properly. Ther is some kind of actuator or cable controlled door that dictates hot or cold. Be sure both of those doors are working properly before replacing the control head
Monday, July 9th, 2007 AT 7:53 AM
METATLVI
Thank you
Tuesday, July 10th, 2007 AT 10:10 PM
2CARPRO JACK
  • 11,533 POSTS
Hope it helped
Wednesday, July 11th, 2007 AT 7:24 AM
Related Air Conditioner Not Working Content
