2004 Buick Rainier Floating Gauges
2004 BUICK
MISSTISH2007
4.2 liter/76k miles and I have floating gauges on my instrument panel which include the Speedometer, RPM & oil guages. The speedometer is on 0-70mph when the car is off; The RPM and oil guages are not on zero when the car is on or off. Its crazy. Someone please help in DFW Texas! What should I do? Do I need a new instrument panel cluster or can the guages be reset?
Nov 6, 2007 at 9:09 AM
98RANGERXLT
  • 301 POSTS
Possible fuel puump going out
Aug 23, 2007 at 12:43 PM
JWALTH02
  • 180 POSTS
You said the light came back on two weeks later? Is it still on? Did you get the codes pulled again when it came on? Lets not throw parts at it till we can figure something out.
Aug 23, 2007 at 7:25 PM
DENNYP
  • 1,824 POSTS
[quote:77537476b8="MissTish2007"]4.2 liter/76k miles and I have floating gauges on my instrument panel which include the Speedometer, RPM & oil guages. The speedometer is on 0-70mph when the car is off; The RPM and oil guages are not on zero when the car is on or off. Its crazy. Someone please help in DFW Texas! What should I do? Do I need a new instrument panel cluster or can the guages be reset?[/quote:77537476b8]I think you need a new cluster.You could try to have the dealership attempt to reprogram the cluster.
Nov 6, 2007 at 10:44 AM
Suggested Repair
Replace the instrument cluster, or have a dealership try reprogramming the cluster first.
Conversation Summary
The owner of a 2004 Buick Rainier with 76,000 miles reported floating speedometer, RPM, and oil gauges that do not rest at zero, including a speedometer reading when the vehicle is off. One reply suggested a fuel pump issue and another discussed a warning light and codes, which did not match the cluster complaint. The relevant expert reply recommended a new instrument cluster, with a possible dealership reprogramming attempt first.
