1999 Buick LeSabre Oil Pressure Gauge
LAWSTUD
the oil pressure monitor on the left side of my dash does not work.
It just hangs way to the left. I looked at the oil pan and noticed the connection seemed fine.... do not know what else to do.
(1999 Buick LeSabre)
Sep 27, 2007 at 8:57 AM
  • 55,851 POSTS
try replacing the oil pressure sender, it s connected by the oil filter and mounted into the block. Please let me know how it goes.
Sep 27, 2007 at 9:09 AM
LAWSTUD
thanks for replying.
I'm confused. What is an oil pressure sender? I got a manual book from the manufacturer and the closest thing to the oil filter is an "oil pressure relief valve."
Is that it?
The troubleshooting for no oil pressure says
1. replace oil pressure switch (what the heck does that mean? the electrical connection to the oil pan? )
8. a stuck pressure regulator valve:
- check the valve for sticking in the bore (again what the heck does that mean???)
-- check the bore for scoring and burrs....
this has got me no where, I cant find this part anyways online. Nor anything about an oil pressure sender.
again I'm stuck.
Oct 17, 2007 at 12:42 PM
  • 55,851 POSTS
Yes the oil pressure sender or oil pressure switch is the part I would change first, it is usually the problem and only costs about $10.00. if this doesn't work let me know. It is located near the oil filter in the engine block not the oil pan. Usually a one wire connector.
Oct 17, 2007 at 2:37 PM
Suggested Repair
Replace the oil pressure sender (also called the oil pressure switch) first. It mounts in the engine block near the oil filter, usually with a one-wire connector, and typically costs about $10. It is not the oil pressure relief valve or a connection on the oil pan.
Conversation Summary
The owner of a 1999 Buick LeSabre reported that the dash oil pressure gauge hangs far left and does not work. They checked the oil pan connection and were confused by the manual's references to an oil pressure relief valve and switch. The expert advised replacing the oil pressure sender or switch near the oil filter in the engine block first, as it is the usual inexpensive cause.
