1998 Buick Lesabre dash venting
444FIRE
  • 1998 BUICK LESABRE
  • 6 CYL
  • 75,000 MILES
Dash vents don't blow a/c @ start-up - blows onto windshield. 3-5 mins. A/c comes out dash vents. Why and how to fix. Thanks.
Wednesday, February 24th, 2010 AT 8:17 AM
DENNYP
  • 1,824 POSTS
Are you saying it is slow to switch from windshield to dash vents?
Wednesday, February 24th, 2010 AT 10:59 PM
444FIRE
  • 21 POSTS
Yep - very slow. When set on "auto" with temp @ 60 it doesn't blow out the dash vents, even when I manually direct it to "mid".
Thursday, February 25th, 2010 AT 6:34 AM
DENNYP
  • 1,824 POSTS
Air Delivery Improper
Step
Action
"Â Engine idling.
"Â Check for vacuum on the main vacuum supply source at the HVAC Programmer Vacuum Line Connector.
Is vacuum present?
Go to Step 2
Go to Step 5
2
Using a vacuum pump, apply vacuum to each actuator line at the HVAC Programmer Vacuum Line Connector.
Do all the lines hold vacuum?
Go to Step 3
Go to Step 4
3
Inspect the actuator doors for binding.
Did you find and correct the condition?
Go to Step 7
Go to Step 6
4
Inspect each vacuum line for an open or restriction, if no open or restriction was found replace the appropriate actuator.
Go to Step 7
5
Locate condition and restore vacuum to source line.
Go to Step 7
6
Replace the HVAC Programmer.
Go to Step 7
7
Operate the system in order to verify the repair.
Did you correct the condition?
System OK
Thursday, February 25th, 2010 AT 1:36 PM
444FIRE
  • 21 POSTS
Good info denny - where is the programmer vac line connectors located? How do I access them? Thanks.
Friday, February 26th, 2010 AT 7:05 AM
DENNYP
  • 1,824 POSTS
If I remember correctly, they are under the passenger side of dash.(Behind glove box)
Friday, February 26th, 2010 AT 11:03 AM
