1999 Buick Park Avenue Fuel Gauge Moves
KCAMPBELL
1999 Park Avenue 134000 miles 3800 The fuel gage is moving while powered up. Moves from full to empty, and back to actual level. When the dash is tapped or a bump is hit while driving, it returns to the actual level as well. Any idea what that is?
Sep 19, 2007 at 2:44 AM
CLY
  • 308 POSTS
Check the connections at the back of the cluster. If all your connections are good then the most likely cause is a loose connection inside the cluster assembly. It will have to be removed and sent out for repair.
Cly
Sep 20, 2007 at 10:22 PM
Suggested Repair
Check the connections at the back of the instrument cluster. If they are secure, a loose connection inside the cluster is likely; remove the cluster and send it out for repair.
Conversation Summary
The owner of a 1999 Buick Park Avenue reports the fuel gauge moves from full to empty and back to the actual level while powered, and returns to the correct reading when the dash is tapped or a bump is hit. The expert advises checking the connections at the back of the cluster; if those are good, a loose internal connection is the likely cause and the cluster should be removed and sent for repair.
