1994 Buick Lesabre Control Arm Bushing Fix
MELLOWMOI
I have a 1994 Buick Lesabre. I need to know what tools I'll need to replace the upper and lower control arms bushings on both sides. It looks like a fairly simple job, but I'm not sure if I need to dissamble anything to put the new ones on. Any help would be greatly appreciated!
94 Lesabre, 120k, 3.8l
Oct 12, 2007 at 7:56 AM
MERLIN2021
  • 17,250 POSTS
94 Lesabre is front wheel drive there are no upper control arms... as for the lowers, easier to buy a new control arm complete! Un bolt the old one seperate the ball joint, and install the new one...If you want to go the hard way, you'll need a ball joint press with bushing attachments.
Oct 12, 2007 at 8:10 AM
Suggested Repair
This front-wheel-drive Lesabre has no upper control arms. Replace the lower control arms as complete assemblies: unbolt the old arm, separate the ball joint, and install the new arm. Pressing bushings instead requires a ball joint press with bushing attachments.
Conversation Summary
The owner of a 1994 Buick Lesabre asked which tools are needed to replace the upper and lower control arm bushings on both sides and whether anything must be disassembled. The expert explained that this front-wheel-drive car has no upper control arms and recommended replacing the lower arms complete rather than pressing in bushings. The harder bushing-only method requires a ball joint press with bushing attachments.
