HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Lesabre
Engine
Symptoms
Noise
1992 Buick Lesabre
RAMONAMAYA
MEMBER
1992 BUICK LESABRE
6 CYL
2WD
AUTOMATIC
159,000 MILES
My auto is making a lot of engine noise
Sunday, October 26th, 2008 AT 1:34 PM
MECHANIC
Hi:
Can you describe the noise you hear, when it happens, how often. Is the car overheating?
Make sure there is oil in the engine and coolant in the radiator.
Monday, November 3rd, 2008 AT 8:00 PM
Please
login
or
register
to post a reply.
Related Engine Noise Content
Grinding Noise Under The Hood
1997 Buick Lesabre Limited, 83,335 Miles, 3800 Engine. After The Engine Has Started, I Hear A Grinding Noise In The Engine Compartment....
Asked by
Jock
1 ANSWER
BUICK LESABRE
GUIDE
Engine Noises
Today's car engines are designed with more complexity and moving parts than ever before. When you hear abnormal noises there is something wrong. Some high output engines...
1992 Buick Lesabre Car Will Not Stay Running
Hi I Have A Question. My Car Will Not Stay Running Sometime Unless My Foot Is On The Gas Then It Is Fine. Sometimes If I Stop At A Stop Sign...
Asked by
angelco04
1 ANSWER
1992
BUICK LESABRE
1992 Buick Lesabre Car Dies At Random - Need Help...
Engine Performance Problem 1992 Buick Lesabre Automatic 122500 Miles Hello! I'm Having A Problem That Is So Random, My Mechanic Can'...
Asked by
Chris C
1992
BUICK LESABRE
1992 Buick Lesabre Recent Low Idle
As Of 4-26-08 My Buick Has Had A Lower Than Normal Idle And Now I Have To Slightly Press The Gas Pedal Down To Start It. Within The...
Asked by
jjdacool
1992
BUICK LESABRE
1992 Buick Lesabre Car Stalls While Driving
Went To Start Car And Nothing Put On New Starter Cylinoid Same Thing Played With Gear Shift And Got It To Start In Nuetral Ran Fine For Few...
Asked by
hortonpnky
1992
BUICK LESABRE
VIEW MORE
Engine Oil Change and Filter Replacement
Oil Change & Filter Replacement Ford Taurus
White Smoke
