Went to start car and nothing put on new starter cylinoid same thing played with gear shift and got it to start in nuetral ran fine for few days went to back out of driveway died wouldnt start same as before jumped the cylinoid started got about 2 mile down the road dummy lights started blinking and car died going at 45 mph had to jump sylenoid thought maybe was nuetral safety not so sure now what should I check now
SPONSORED LINKS
Wednesday, June 11th, 2008 AT 9:55 PM
LEGITIMATE007
MECHANIC
Check crankshaft position sensor, map, and alternator
Wednesday, June 11th, 2008 AT 9:58 PM
LEGITIMATE007
MECHANIC
Dont forget battery and connections for frays, and corrosion
Check if you have a security light on or blinking
check the key and security system
if car start in neutral but not in park I would suspect a bad neutral safety switch
