1997 Buick LeSabre Grinding Noise
JOCK
1997 Buick LeSabre Limited, 83,335 miles, 3800 engine. After the engine has started, I hear a grinding noise in the engine compartment. The noise stops "after" the defroster has been turned on. Is this a compressor or a blower motor issue? Also, I've been quoted compressor prices ranging from $200 to $400., which does not include labor. Would I fare better by purchasing the compressor from an auto parts store, and having a shop mechanic install it? Labor rates range from $47 to $60 pr. hr. HELP!! Thanks!
Oct 8, 2007 at 11:41 AM
CLY
  • 308 POSTS
Sounds like you have a compressor clutch that is going bad. As soon as the compressor kicks in the clutch engauges and the noise probably stops. You may check on just replacing the compressor clutch assembly. Might save ya alittle money....
Cly
Oct 12, 2007 at 9:19 AM
Suggested Repair
Inspect the A/C compressor clutch and consider replacing the clutch assembly rather than the entire compressor, since the grinding likely stops when the clutch engages.
Conversation Summary
The owner of a 1997 Buick LeSabre hears a grinding noise under the hood after startup that stops when the defroster is turned on, and asks whether the compressor or blower motor is at fault and whether to buy a compressor separately. The expert says the compressor clutch is likely failing and suggests replacing the clutch assembly to save money.
