1989 Buick Lesabre
ROBERTTHORNBURG
  • 1989 BUICK LESABRE
  • 6 CYL
  • FWD
  • 181,469 MILES
I UN HOOKED BATTERY NOW CAR WILL NOT IDLE. WHEN STOPPED & TURN SIGNAL IS ON THE FUEL PUMP SPEEDS & SLOWES DOWN WITH THE TURN SIGNAL OR WHEN STOP & GOING THE FUEL PUMP SPEEDS UP & SLOWS DOWN.
Saturday, February 9th, 2008 AT 6:10 PM
MASTERTECHTIM
  • 4,750 POSTS
On this engine 3.1T there is a process to reset the idle using a gm scan tool, but unfortunately you dont have one, I would start by cleaning the idle air control valve and clean out the throttle body and disconnect battery again, reconnect battery and drive vehicle over 40 mph for 5 minutes if at all possible, this is the generic way of setting the iac valve. Hope this helps
Saturday, February 9th, 2008 AT 6:31 PM
