Hello, are there any codes? Your obd1, you should be able to check the codes, yourself. As far as the fan on some models, if the CTS is unplugged, the fan comes on, if the ac controls are on, the fan my run. I can't tell, It might be an issue with the cts.
As far as idle, I'd look at the idle air control system.
SPONSORED LINKS
Monday, March 9th, 2009 AT 12:14 PM
