Break light
300,000 MILES • 0.8L • V8 • 4WD • AUTOMATIC
COTTONTOP88
Break lights won't work. Everything else works except the break lights I replaced te switch by the pedel thinking it might be bad but no go. There was a white wire in the harness under the truck that lights up when te pedel is pressed but it wasn't hooked up to anything and I can't figure out we're it goes or if it is even supposed to be hooked up
Jan 2, 2016 at 7:08 AM
HMAC300
  • 48,601 POSTS
check the ground on lh rear frame first then check to see if power is going to t/s switch the white wire that goes off of brake light switch should go to t/s switch that's probably why your lights don't work. it's probably broken off or cut
Jan 2, 2016 at 7:38 AM
