Ok ill fix the charging issue first. Thanks for your help and I will get back to you.[/Quote:7ac56e011f]
Well I went to the garage to check the negative terminal cable, and I wasn't able to see underneath the car due to snow. I was able to get a booster pack and fire up the car. I went to start the car up and it worked fine but the absolute minute I took the negative booster off, the car died. I hope that was enough info for now until I can get more[/quote:7ac56e011f]
Hi. Me again, I realized already that my alternator was burnt out, but that scrap guy at the garage says that there might be a problem with the ignition system that may cause the alternator to burn out. Could he be right?
Monday, March 12th, 2007 AT 9:28 PM
