Brake lights
220,501 MILES • 1.6L • 4 CYL • FWD • MANUAL
IVANDIAZ
While my lights are off or on, if I press the brakes my hazard lights are the ones that turn on. If I use my turn signal it seems as if my hazards want to turn on and my digital clock on my dashboard will also flash. Almost forgot to mention I have no dashboard lights. Please help. Thank you.
Feb 20, 2017 at 7:30 AM
  • 31,937 POSTS
start with checking all the electrical earth points as it sounds as if the problem may be here, has the car been at a panel shop reticently?
Feb 20, 2017 at 4:30 PM
IVANDIAZ
I am not sure what you mean by earth points. No the car has not been at a panel shop.
Feb 20, 2017 at 10:57 PM
  • 31,937 POSTS
Battery earth and main chassis electrical earth points, if you are unsure a mechanic can do this fairly quickly
Feb 21, 2017 at 2:37 PM
