Brake light issue
196,127 MILES • 4.0L • 6 CYL • 4WD • AUTOMATIC
JEEPOWNER01
When I hit the brake pedal my front marker lights and dash lights come on. When I turn my headlights on all three brake lights stay on. Checked all the fuses replaced the brake switch, tried to locate a relay and could not find one. Any ideas how to fix this?
Dec 4, 2018 at 1:18 AM
Good morning,
It sounds like the bulb or sockets in the rear are the issue. Check and make sure the bulbs are correct.
https://www.2carpros.com/articles/brake-lights-not-working
Check the sockets as well for any corrosion.
This is common with either a bad socket or ground. It is not a relay or fuse.
Dec 4, 2018 at 1:24 AM
