1986 Jeep Cherokee Soft Brakes
RFAWCETT
I have a 1986 cherokee with a 2.6l. v-6, after coming home from iraq i went to drive my jeep witch has set-up in the garage since i left, the problem is i have no brakes unless i pump them at med. speed 7-12 times before they catch and then it is lousy at best, i did notice a leak between master cylinder and brake booster,but not to bad it does not want to have any brakes without babying them,but that is the only problem that i can see the brake light stays on any response would be greatful,as this is the only thing that was not taken while i was gone.
Oct 29, 2007 at 10:59 AM
2CARPRO JACK
  • 11,533 POSTS
If the master is leaking, then start by replacing that. Check pad/shoe thickness and look for leaks at the wheels as well. Probably sucked air in through the bad master cylinder and will need a good bleeding....BTW Welcome Back.. any other questions feel free to PM me
Oct 29, 2007 at 11:06 AM
Suggested Repair
Replace the leaking master cylinder, inspect pad and shoe thickness and check for leaks at the wheels, then thoroughly bleed the brake system to remove air.
Conversation Summary
The owner of a 1986 Jeep Cherokee that sat unused reports almost no brakes unless the pedal is pumped many times, a leak between the master cylinder and brake booster, and a brake warning light that stays on. The expert advises replacing the leaking master cylinder, checking pad and shoe thickness and wheel leaks, and bleeding the system because air was likely drawn in through the bad master cylinder.
