Check lt. Blu wire to see if there is power there, it may be a bad socket or a bad ground. It grounds to spare tire bracket under truck. If no power it is broken wire or bad connection at very rear cross frame there should be a circuit board that may be the problem as well it' s on lh side of truck
SPONSORED LINKS
Wednesday, December 23rd, 2020 AT 1:32 PM
(Merged)
