Stalled and will not restart
2004 BMW 325I
90,000 MILES • 6 CYL • 4WD • AUTOMATIC
ED FRICKE
After long hot drive car stalled at roundabout, restarted and has not stalled since?
Jul 7, 2018 at 7:44 AM
  • 110,236 POSTS
If I understand correctly, it stalled but restarted and has been fine since. Is that correct?
If that is the case, many things can cause such an issue. If the air conditioning was on and temperatures were really high, there could have been a heavy drag on the engine just from the compressor, alternator, power steering pump. A slight delay from the idle air control valve may have allowed the rpm's to drop low enough to stall.
Also, if there is a problem, in most cases the check engine light would have come on to indicate a problem. Has that happened? If is has, here is a quick video showing how to retrieve the codes:
https://youtu.be/YV3TRZwer8k
If my understanding is correct and the check engine light did not illuminate, there really is not much that can be checked until it happens again or it refuses to start.
I hope this is helpful. Let me know if you have other questions.
Jul 9, 2018 at 11:45 AM
