BMW 735iL Right Side Lights Out
1973 BMW
BULLDAWG1
My rightside front headlight is out. My rightside parking light is out. My rear brake light is out. My right side front and rear marker lights are out. Also my instrument panel dash is lighting up either.
Oct 22, 2007 at 8:08 AM
DOCHAGERTY
  • 9,606 POSTS
check the fuses and report back
Oct 29, 2007 at 4:08 AM
735IL
I just had this problem in my '89 735iL. Every car is different but the guy who fixed it said that the lamp control module was bad. It is not a cheep part so try the fuses first. I would recomend a repair manual from Bentley Publishers.com. there you can trace the wiring down if its not a fuse before you go and buy a 350 dollar part. good luck.
Mar 22, 2008 at 10:55 AM
Suggested Repair
Check the fuses first. If they are good, trace the right-side lighting circuits with a Bentley repair manual before replacing the expensive lamp control module.
Conversation Summary
The owner reports that the right front headlight, parking light, rear brake light, side marker lights, and instrument panel lighting are out. An expert advises checking the fuses. Another 735iL owner says a failed lamp control module caused similar symptoms, but recommends verifying fuses and tracing the wiring before buying that costly part.
