2003 bmw 325i 30000 miles
Dec 29, 2006 at 6:48 AM
Check the driver headlight connector for a solid connection to the lamp pins, without touching the bulb glass. Inspect the ground for tightness and corrosion. If both are good, the bulb filament may be broken and opening with vibration.
The owner of a 2003 BMW 325i reports the driver headlight turning on and off. The expert advises checking the lamp connector, confirming the ground is tight and free of corrosion, and considering a rare broken bulb element that contacts until vibration opens it.
