revs are eratic, high fuel consumption, could it be the injectors or somthing more serious.....
The engine has done 75000 miles of careful driving, any ideas would be helpful
Stop driving to avoid further catalytic converter damage. Diagnose the cause of unburned fuel entering the exhaust, scan the PCM for codes, and check at least one oxygen sensor before replacing the damaged converter.
The owner of a 1994 BMW 325i with 75,000 miles reports rough running, loud backfires, erratic revs, high fuel use, and a glowing exhaust, and asks whether the injectors or something more serious is at fault. The expert says a glowing exhaust indicates a damaged catalytic converter caused by too much unburned fuel, warns that continued driving will cause more expensive converter damage, and advises fixing the engine first, checking for flashing check-engine codes in the PCM, and inspecting at least one oxygen sensor.
