1995 BMW 325 Clacking noise
ROBINSOUND
Steering problem
1995 BMW 325 6 cyl Two Wheel Drive Manual 206K miles
When I reach the speed of 45 and above and turn my wheel slightly to the right, my car goes clack clack clack clack vigorously and the steering wheels shakes too. Im not a mechanic, but I do know how to work on cars. This ones got me.
Thanks
Scott
May 23, 2010 at 5:05 AM
DR LOOT
  • 2,311 POSTS
[quote:da6823d785="Robinsound"]Steering problem
Thanks
Scott[/quote:da6823d785]
The first thing to do with any suspension or steering problem is to eliminate tires as the possible source of the problem. If you can't find a good set of tires to change to, then at least rotate them around to see if the problem moves. Your problem sounds like a separated tread to me.
Good Luck,
Dr Loot's Assistant
May 26, 2010 at 1:44 AM
