2003 BMW 525 Check Brake Lights
E4BNAV
I have a 2003 BMW 525i and i recently got the "CHECK BRAKE LIGHTS" message. I checked all the brake light bulbs, including the deck stop lamp and they all appeared fine and all the brake lights illuminate when the brake pedal is pressed. I didn't see any signs of corrosion in the brake light holders either. What could be causing this message and how do I get rid of it?
Barry
Aug 14, 2007 at 11:53 AM
DOCHAGERTY
  • 9,606 POSTS
this fault is often caused by a connector corroding. inspect all connectors and grounds and use only the BMW light bulbs. repost if you need more help.
P.S isn't the car still under warranty?
Aug 14, 2007 at 6:25 PM
E4BNAV
Unfortunately the warranty expired just prior to this problem (go figure). I did see another thread where this problem is usually fixed by replacing a switch behind the brake pedal. I think I will try that now since I haven't found any corrosion in the connectors.
Aug 21, 2007 at 2:59 PM
Suggested Repair
Inspect all brake-light connectors and grounds for corrosion, and use only BMW-specified bulbs.
Conversation Summary
The owner of a 2003 BMW 525i has a Check Brake Lights message even though all brake lights illuminate and the bulbs and holders look fine. The expert says a corroded connector is a common cause and recommends inspecting all connectors and grounds and using only BMW bulbs. The owner later considered replacing the brake-pedal switch after finding no corrosion.
