1995 BMW 530i rough idle
1995 BMW 530I
85,000 MILES • V8 • 2WD • AUTOMATIC
WINDSOR ACR
the car has been great for years now suddenly as it gets warmer the car seems to idle rough especially in the cooler mornings
acceleration can be laggy at times
you really notice the problem at a stop light when the car is bucking around and vibrating, once i get on the gas to go the engine smooths out around 1000 rpm and it's good to go till the next light
what should I do to fix this?
I haven't tried anything yet
thanks in advance
R.
May 11, 2010 at 1:54 PM
DOCHAGERTY
  • 9,606 POSTS
The first thing to check is the PCV plate on the rear of the intake manifold(part #3) they have a tendency to fail and cause the issues you report.
May 11, 2010 at 2:28 PM
WINDSOR ACR
is the pcv plate repairable or will I need to buy a new one before digging into things?
May 12, 2010 at 7:12 AM
DOCHAGERTY
  • 9,606 POSTS
Replacement is the path, repair is not an option. The T-30 Torx screws can be removed with the manifold in place, be careful when removing the screws, the heads can strip out very easily. I usually replace them with regular hex head bolts.
May 12, 2010 at 9:40 AM
WINDSOR ACR
thanks!
I'll try it
May 12, 2010 at 10:57 AM
DOCHAGERTY
  • 9,606 POSTS
Cool, keep in touch.
May 13, 2010 at 9:37 AM
