1986 BMW 528E Battery Drain
BIG O
hey i have a 1986 BMW 528E and the battery seems to drain and i was wondering if you guys had any idea wat that might be
thanx
Feb 13, 2006 at 7:41 AM
2CARPRO JACK
  • 11,533 POSTS
could be any 1 of a thousand things, might want to take it to a pro
Feb 13, 2006 at 8:56 AM
ALEX7XELA
I have a few of these cars and twice I have experienced power door locks / fuel door lock sticking, drains battery overnight. Pull fuse to test.
Jun 8, 2008 at 5:35 AM
DOCHAGERTY
  • 9,606 POSTS
Our palindromic friend is correct and I would just like to add the possibility of any number of aftermarket items that often find there way into cars such as alarms or stereos can be a source of a key off draw. Also check the glove box lamp. If this does not fix it repost and we can go deeper.
Jun 8, 2008 at 6:46 AM
Suggested Repair
Check for a parasitic key-off draw. Test by pulling the fuse for sticking power door locks or the fuel door lock, which can drain the battery overnight. Also inspect aftermarket alarms or stereos and the glove box lamp. If those checks do not stop the drain, have a shop perform a proper parasitic-draw test.
Conversation Summary
Owner of a 1986 BMW 528E reports the battery drains. One reply notes that sticking power door locks or the fuel door lock can drain the battery overnight and suggests pulling the fuse to test. Experts add that aftermarket alarms or stereos and a glove box lamp can also cause a key-off draw, and recommend professional diagnosis if those checks do not fix it.
