1999 BMW 520i Stuck Engine Swap Bolts Fix
GLENNPOLLARD
520i 1999
154k miles
Manual
2 wheel drive
I drove through water which cut the engine. When it restarted it made a loud bang and gave off white smoke (injested water). car ran afterwards but with constant ticking sound. Started usuing more and more oil and increasingly fired on only 5 cylinders. Last Sunday the engine went bang! Big end bearing on cylinder 6 let go and smashed out through engine block. I have bought a used engine with only 38k. I ahve started stripping old engine down in car ready for swap over. Though fiddly I have finished everything in the engine bay.
My problem is this - the exhaust manifold bolts and the gearbox bellhousing bolts are proving impossible to undo. Anybody have nay tips?
Thank you. Glenn
Jun 20, 2007 at 1:18 AM
DOCHAGERTY
  • 9,606 POSTS
the exhaust manifolds stay on the engine until it is removed,just remove the down pipe bolts.the bell housing bolts are torx bolts and sometimes can be very difficult to remove sometimes requiring removal of engine and trans as a unit.
Jul 20, 2007 at 5:03 PM
Suggested Repair
Leave the exhaust manifolds on the engine and remove only the downpipe bolts. The bellhousing bolts are Torx and can be very difficult; if they will not come out, remove the engine and transmission as a unit.
Conversation Summary
The owner of a 1999 BMW 520i ingested water, later lost a big-end bearing that broke the block, and is swapping in a used engine. The exhaust manifold and gearbox bellhousing bolts will not undo. The expert advises leaving the manifolds on and unbolting the downpipes, and says the Torx bellhousing bolts may require removing the engine and transmission together.
