2000 BMW 323i Stripped Head Bolt Holes Fix
GEORGE TAYLOR
Gentlemen and ladies, I had some trouble mechanical work done on my 323i.
It’s a BMW 323i 2000 model, in line 6, four doors, with 100,000 miles.
I had some head work done. In the process they over torque the engine head bolts and striped the bolt holes. My question is, can heli coils be used to reset the bolts on a BMW aluminum block and will the torque setting change. They use heli coils on aircraft that is approved by the FAA and they are also used in racing aluminum block engines. I am being told by mechanics, that I don’t have much confidence, in that heli coils can not be used on BMW’s aluminum engines.
They want to replace the block or drop a re-built engine in the car. Either way the cost is about $6000 dollars. The car is paid for. It is only worth between 10 and 14,000 dollars and I don’t want to invest that much money to a car that is quickly losing its worth.
Thanks for all you help,
GT
Jul 23, 2007 at 2:16 AM
DOCHAGERTY
  • 9,606 POSTS
I would say it is worth the risk if it were my car and I was the one doing the work.I would also consider using timeserts instead of helicoils.The torque spec for the bolts should stay the same as these motors use angle torque bolts also know as torque to yield.
Jul 26, 2007 at 9:33 PM
Suggested Repair
Timeserts are preferable to helicoils for the stripped aluminum head-bolt holes. Keep the original torque specification because these engines use torque-to-yield angle bolts. The repair is a reasonable risk versus replacing the block or engine if the owner performs the work.
Conversation Summary
The owner of a 2000 BMW 323i had head work that overtorqued and stripped the aluminum head-bolt holes. Mechanics recommended replacing the block or installing a rebuilt engine for about $6000. The expert said Timeserts are better than helicoils, the torque spec should stay the same because the bolts are torque-to-yield, and the repair is worth trying if the owner does the work.
