1991 Ford Probe Harmonic Balancer Bolt Stuck Fix
JESSE
I have a 1991 ford probe. I have to replace the harmonic balancer in it and im having a hard time getting the old one off. the manual doesn't warn me that as i try to turn the bolt in the middle of the pulley, that the whole pulley will turn with it. so I found a way to keep the pulley wheel still as i turn the bolt. however, the bolt doesn't budge. am I doing something wrong?- - -
Jan 10, 2006 at 10:20 AM
COSMO
  • 347 POSTS
Yah use a 1/2 impact gun and about 125psi coupled with a 21mm socket
Jan 10, 2006 at 1:27 PM
Suggested Repair
Use a 1/2-inch impact gun at about 125 psi with a 21mm socket to loosen the harmonic balancer center bolt.
Conversation Summary
The owner of a 1991 Ford Probe needs to replace the harmonic balancer but cannot remove the center bolt. Holding the pulley still does not help because the bolt will not budge. The expert recommends using a 1/2-inch impact gun at about 125 psi with a 21mm socket.
