BMW 330 White Exhaust Smoke
MELBEE4U
I recently had an oil change, some weeks after (maybe two) my needs servicing light came on. "Knowing that it's that time, I have not hurried to have it service.
Some day's have passed and now I have white smoke coming out of my exhaust.
Idling putt-putt, like it wants to stop, pressing on gas at a red light and it's hesitant.
What's Wrong?
What should I have done and what should I have them NOT do when I take it to the shop!
Sep 12, 2007 at 11:51 PM
  • 75,988 POSTS
[quote:2c17085519="melbee4u"]I recently had an oil change, some weeks after (maybe two) my needs servicing light came on. "Knowing that it's that time, I have not hurried to have it service.
What's Wrong?
:([/quote:2c17085519]
If its not condensation, then the coolant is being burn in the combustion chamber-possible causes blown heagasket cracked head or block-get it pressure test or leakdown test to confirm the leakage area.
Sep 12, 2007 at 11:56 PM
Suggested Repair
If the white smoke is not normal condensation, have a cooling-system pressure test or leakdown test done to confirm coolant entering the combustion chamber. Possible causes include a blown head gasket, cracked head, or cracked block.
Conversation Summary
The owner of a BMW 330 reported white exhaust smoke, rough idle, and hesitation a couple of weeks after an oil change, after delaying service when the service light came on. The expert said that if it is not condensation, coolant is likely burning in the combustion chamber from a blown head gasket, cracked head, or cracked block, and recommended a pressure test or leakdown test to locate the leak.
